Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > The Amateur Radio Spot
Old 12-02-2018, 08:55 PM
dtvmcdonald's Avatar
I too would be interested. Send PM. I've gotten addicted.
Old 12-03-2018, 09:26 AM
I think I downloaded this back when the link worked...
Old 12-03-2018, 11:40 AM
drdave3 drdave3 is offline
Ok. Is there a link? Thank you.
Old 12-03-2018, 02:08 PM
WISCOJIM WISCOJIM is offline
I thought I had also, but I don't know what I filed them under.
Old 01-05-2019, 01:22 PM
radioactive's Avatar
radioactive radioactive is offline
tube gear fanatic
Sorry to all that want the scans that I haven't been on this site for awhile.ill check out my Dropbox and see if they're still there and if so I'll repost a good link.if not I'll have to dig out my computer and find a keyboard and mouse .I'll report back with what I find
real radios glow in the dark...
Old 01-05-2019, 06:01 PM
tube gear fanatic
checked out my dropbox and apperantly i only have 4 issues saved there and will make them public and post a lnk here.as far asvthe other 200+ issues go ill have to find a keyboard mouse and external hardrive that theyre probally on.its been a long time since ive used a actuall computer and dont wven know where my external drive is but ill find it and restore the magazine to my dropbox.
Old 01-06-2019, 09:41 AM
tube gear fanatic
ok ,heres 4 links to 4 issues .a far cry from what was there but its a start until i can getat my computer.
https://www.dropbox.com/s/1qjibxtyoe...%2097.pdf?dl=0
https://www.dropbox.com/s/n2rctv2fv3...%2099.pdf?dl=0
https://www.dropbox.com/s/9jzjz54ngi...%2098.pdf?dl=0
https://www.dropbox.com/s/cg3r0h1nrc...%2097.pdf?dl=0
Old 01-19-2019, 11:08 AM
tube gear fanatic
Update:I finally got my computer up and running and found the folder with the magazine's.i just have to now go out and buy a 50ft Ethernet cable so I can upload them to Dropbox again.i will hopefully be doing this on Sunday.once I have it done I'll report back here with a link.
Old 01-19-2019, 01:34 PM
Once upon a time, I wouldn't have hesitated for a moment to have turned my nose up to ANYTHING that didn't have "R" & "3 XXX in its name, but now I've softened a bit in my dotage. Let's face it, SW basically sounds like @ss most of the time, there's a lot less Englisch programming on every year, & DXing FM signals can be almost as fun, & the audio is WAY better. Look into an SX-42, 43 or 62 from Hallicrafters. You get a receiver that's very nearly as sensitive as the fabled Collins/Motorola R-3(Cough, cough), but along w/a PASSEL of firebottles yr set will get yr local FM purveyor of radio that AIN'T in Swahili/Tagalog/Romulan or Klingon. The 62 DON'T have a BFO, but it DOES have a strong mono FM section, &it was likely styled by Raymond Loewy of postwar Studebaker fame. I don't think they use any bad, oddball tubes, they're big, & servicing them isn't too onerous, what more can you ax for ?!?
Old 01-23-2019, 07:52 PM
tube gear fanatic
Ok try this link.happy reading.
https://www.dropbox.com/sh/w9868ejy5...TYL5qoPTa?dl=0
Old 01-23-2019, 08:17 PM
tube gear fanatic
took awhile but hopefully i managed to get this to work.let me know if it doesnt .regards,
chris
Old 01-26-2019, 03:39 PM
Tim Tress Tim Tress is offline
Hi Chris... Your link isn't working; there seems to be a problem with Dropbox.
Old 01-26-2019, 03:49 PM
tube gear fanatic
Originally Posted by Tim Tress View Post
Hi Chris... Your link isn't working.
hi tim,im sorry but it was but i posted it also on some facebook groups and had such a high amount of traffic dropbox shut it down.also someone probally complained abiut copyright infringement so i had to delete the file from my dropbox so that id be allowed to share other things in my account.if i would of just kept it here and on audiokarma like i did before itd probally be still working.
im trying to figure out how i can share it again only to certain people i choose.i might go google drive but have to look into that.if you have any other ideas im open to ideas.the file size is 1.3g so email is out of the question
Old 01-26-2019, 03:53 PM
I was wondering what happened.
Too many requests
Sorry, this link has been automatically turned off for now. Learn more about traffic limits.
Old 02-21-2019, 10:12 AM
I'd sure like to get a copy. I could send a send-to only link at my Box.
Doug McDonald
[email protected]
