Old 02-11-2022, 03:38 PM
Assuming that's through the tuner, have you tried signal injection at any other points?
Old 02-11-2022, 04:55 PM
It is and, no, I haven't. The generator I'm using is for 44 MHz IF. I'd have to dig out my B&K 1077.
Would this be caused by the incoming signal? I was assuming it's an issue with some 60 cycle line voltage getting into the deflection circuit
Old 02-11-2022, 08:12 PM
I wouldn't think, but it's always comforting to rule out the unexpected if it's not too difficult.If nothing else inject directly to the video amp. Have you tried adding another large value filter cap in parallel across the various points feeding B+ the horizontal circuits?
Old 02-11-2022, 08:39 PM
No, not yet. Another clue is that it's affecting the vertical too as can be seen in that video clip. Perhaps it's as simple as more B+ filtering
Old 02-12-2022, 06:52 PM
Nope, B+, B++ and B- rails are clean. I probed the oscillators and they both have 60Hz sine riding on the sawtooth waveforms. Thinking tube HK or socket leakage
Old 02-13-2022, 12:35 AM
I switched to a better scope and took some screenshots.
Here's the ripple riding on the horizontal deflection plate sawtooth
I was mistaken, there is about 12 VPP ripple on the 350 B++ rail.
I tried tacking in various filter caps near the deflection amps. Eventually, I got up to 120uF. That brought the ripple down to about 2 volts.
However, that had no impact on the display distortion. Very frustrating.
Old 02-13-2022, 01:13 AM
Something else I just discovered. The tuner has 14 positions! More evidence that it's not the original.
Old 02-13-2022, 09:53 AM
Did you also try filtering the +300 V and/or -120V more?
Old 02-13-2022, 11:38 AM
Yes, no improvement. There's only about 50mV ripple on B- but it does find its way into the cathodes of both horizontal and vertical multivibrators. Then it gets amplified along with the sawtooth. I tried tacking in a couple 22uF caps on B-, but it made no difference.
The only thing I haven't tried at this point is adding more filtering to B+. Since it's not used in the deflection circuits I figured why bother, but I'll give it a try.
Old 02-13-2022, 01:32 PM
Just wondering.. isn't the vert sweep from your signal source(s) locked to the AC mains frequency? If so, the bend should be stationary and not undulating. Whereas an over-the-air signal would show a slowly-moving bend. Or maybe I'm having a 'senior moment'.
Old 02-13-2022, 02:12 PM
No, the vertical of my test pattern generator is not locked to the mains
Old 02-13-2022, 02:43 PM
Time to dig the B&K analyst out. I believe they are synced to the AC line. I had this same weird thing going on several years ago, although not a static deflection set, but on the B&K it was rock solid. We never did come to any conclusion on how to cure it, but it's works fine with a DVD player through an agile modulator. Conclusion was it's an over the air sync issue.
Old 02-13-2022, 04:49 PM
Tom9589 Tom9589 is online now
Kevin, you are correct about the 1077 B&K. The vertical sync signal is derived from off of the main power transformer. The horizontal sync signal is derived from a 189 KHz crystal osc and a divide by 12 divider which equals 15,750 Hz. At one time, the 189 KHz crystal in my 1077 developed a cold solder joint and the 189 KHz signal was missing. The horizontal oscillator kept running, but it varied all over the place in frequency. Nudge the crystal and the horizontal frequency snapped into sync.
Old 02-13-2022, 05:17 PM
OK, I injected to the grid if the 2nd IF. Now, the image is stable.
Old 02-13-2022, 05:33 PM
This is interesting, but I don't understand the DVD player case, because a DVD player should not be locked to the line.
