Old 05-31-2023, 09:06 AM
JohnCT's Avatar
JohnCT JohnCT is offline
Originally Posted by pac.attack76 View Post
Even if I used the whole board, it wouldn't fit the tubes pins.
Did you try? Even thought the sockets are different the pin spacing should be the same. In any case, which one is the one you need? I might have the other one as well.
John
Old 05-31-2023, 09:24 AM
pac.attack76's Avatar
Stuck in the past
John
Yes, the smaller one.
Genesis does what Nintendon't
Old 05-31-2023, 01:18 PM
JohnCT's Avatar
See if the larger one fits the tube - it should have the same spacing. If it does fit and the board has the same layout, just wire it in. If it doesn't fit or the board is different, let me know and I'll check the dungeon for the smaller socket and/or board.
Post a pic of the original board.
John
Old 05-31-2023, 02:25 PM
Stuck in the past
John
I couldn't get it to fit and the boards have different wires/components .
Old 06-01-2023, 09:43 AM
JohnCT's Avatar
Post a pic of the original board, I might have one. If not, I can get you just the socket.
John
Old 06-01-2023, 09:52 AM
Stuck in the past
John
Ok 👍
