Old 12-02-2025, 11:00 AM
Carmine's Avatar
Carmine Carmine is offline
...enjoys spaghetti.
I have heard of that source, but as you said they supply manufacturers. Their minimum order is 500 with a 20 week lead time.
From Captain Video, 1/4/2007
Old 12-02-2025, 01:15 PM
Try mouser then. It's rare that both of them won't have a minimum quantity of 1 option for a part...both sites work wonky on a smartphone which is all I can use to post from during business hours.
Old 12-02-2025, 02:50 PM
vol.2's Avatar
vol.2 vol.2 is online now
That's actually not true at all. Tom just didn't notice the minimum because it's very unusual for them to have one. Digikey is mainly a solution for medium sized companies and individuals. Big companies deal directly with the manufacturers to get better volume discounts. I have done this for work for many years, and we only used places like this for prototyping and small runs of things.
Just learn to use the parametric search function and you'll be able to find whatever you need. Here's four choices for you:
https://www.digikey.com/en/products/...3JIKjY%2BJVygA
Old 12-02-2025, 04:05 PM
Carmine's Avatar
Thank you. I suspected they did sell smaller numbers but could not seem to work around it on either the linked Digikey site or Mouser. I ordered 10 for the better pricing and just to keep some on hand. I also ran across this site on my own which some of you might find helpful:
https://octopart.com/
Old 12-02-2025, 08:46 PM
I don't know much...but a socket thought is to grab a brightener and just cut the socket off that.
Old 12-02-2025, 10:34 PM
vol.2's Avatar
You're welcome.
Octopart is actually a secondary market seller. They do have some basic stock, but they primarily source parts from other places when orders are placed for most things.
I would avoid using them as they charge a premium for "finding" stock. You're better off just ordering directly from a resale place like Digikey or Mouser.
If it's too rare for that, then go directly to ebay and look for a seller with good feedback.
Old 12-02-2025, 11:05 PM
BeamT BeamT is offline
I've not seen Octopart, good to know, interesting they are a secondary seller.
Mouser Part # 667-ECW-HA3C182H4 Panasonic .0018uf (1800pf) 1.6kv 3%
600+ In-Stock, $.46 each with a Qty. of 10. They do advise:
"A tariff of 44 % may be applied if shipping to the United States."
Beam_T
Old 12-08-2025, 06:57 PM
Carmine's Avatar
Oh frustration...
The new caps have been installed. HV is down where it should be (as is focus voltage per the "corrected" Sam's). Focus is now worse than ever. Best focus is now at the extreme clockwise (it was almost perfectly centered earlier). Whereas before, the picture was "watchable" it's now a blurry mess. Although, as before, lower brightness does improve the focus, but anything approaching normal requires an almost invisible picture.
Photos show a dark and "normal" screen HV readings
Beyond the safety caps, I did notice a 10mfd @300v cap right next to one of the "middle chassis" safety caps that had to be open, it pretty much fell apart in my hands. Luckily I have a decent electronics store at literal walking distance, so I was able to buy this cap in a 350v rating. I don't have my laptop/Sams nearby, so I'm not sure which circuit this involves.
I'd be inclined to think I really screwed something up except that by "specifications", (HV and focus V readings), I'm better than before. What gives?!
Old 12-08-2025, 07:51 PM
If it uses a focus divider start with that. They usually crack, bulge, change color or melt. There may be a kit ( 800-616 ) but you need to up sub
from the OEM 63-#### I can help you with that.
If no divider the tripler just has focus out ( to CRT ) and control lines.
The cap was probably the boost cap. It would get too much DC on it
if the HV goes high & it brews up. Keep it in mind. It is one of the most
common fail on ALL brands from apx 1978 til the end of TV. It can
cause MANY different symptoms.
C U Later
Zeno
Old 12-08-2025, 08:02 PM
damen's Avatar
damen damen is offline
Use the high voltage meter to check and see if you get any voltage on the focus pin of the CRT with the socket unplugged. If there's leakage from the anode connector to the focus pin inside the CRT it can cause the focus voltage not to track with the high voltage. If you measure voltage, use a grounded clip lead and touch the focus pin, if it "pops", like discharging the anode, it may correct the problem.
Old 12-08-2025, 10:05 PM
Carmine's Avatar
I'll try this in the morning. You're suggesting discharging the focus pin like a 2nd anode if I read this correctly?
Old 12-08-2025, 10:11 PM
Carmine's Avatar
The cap I replaced is number 270 in the schematic. 10 mfd @ 300v
It's an electrolytic, but I'm still not sure of the circuit yet.
I was always taught to trouble shoot by first looking at what has changed... I changed caps that tune the HV circuit, it brought down my HV and focus voltage. Now the picture looks worse than before when there were open caps. Seems to me the issue has to be related to that, not a coincidental new failure?! I will give that focus pin discharge a shot in the morning.
Old 12-09-2025, 02:17 PM
Carmine's Avatar
I did try to discharge the CRT focus pin. No pop and wasn't able to read anything. No change in the picture.
I measured focus voltage again and it seems low, although this type of meter isn't exactly precise. As I mentioned earlier, the SAMS has a hand-drawn correction that says 3.5KV. One could argue this is almost 1/3 of the way to 10KV.
The focus divider isn't showing any physical issues. Are there other voltage points I should try?
Old 12-09-2025, 03:02 PM
vol.2's Avatar
Yes, you changed some stuff, but that doesn't mean that what you did "messed it up." In fact, your repair very likely just exacerbated a pre-existing issue.
Old 12-10-2025, 09:35 AM
Might be worthwhile to readjust the screen/G2 controls for the CRT. Proper setup varies with HV.
