Old 11-26-2005, 03:01 PM
yagosaga's Avatar
yagosaga yagosaga is offline
VK Member
Originally Posted by mbates14
You know, I just thought of some crazy idea yesterday.
Use an array of UV LEDs for the light source, but on the disk, instead of holes for scanning, use a UV pen, and and mark where the holes supposed to be, so in the dark, its got a cool looking effect.
Then I have to look on the back side of the disk. But why not using UV LEDs with holes in the disk and put a phosphored screen before the disk?
Old 11-26-2005, 03:37 PM
mbates14 mbates14 is offline
because I dont want to look through holes, and I want maximum brightness.
Old 11-26-2005, 03:53 PM
David Roper's Avatar
console lover
May I recommend a CRT then?
tvontheporch.com
Old 11-26-2005, 04:02 PM
lol.
Naa, I wondered what effect that would look like if I used a UV marker for the scan holes. I wonder.....
Old 12-02-2005, 04:12 PM
Yagosaga, that is very nice looking, and I also like having the works visible so people can see what's in it.
Old 12-15-2005, 12:03 PM
hehehe, I just got an idea, that might improve picture definition and brightness.
I got an old fiber optic toy lying around, I might just cut a strand, and cut that strand into 32 small peices, and they are VERY small fine optic wire.
And glue them into each sync hole, and that optic cable passes all light, and its small enough to achieve picture definition.
Im going to try this.
Old 12-15-2005, 02:32 PM
yagosaga's Avatar
VK Member
hehehe, I just got an idea, that might improve picture definition and brightness. I got an old fiber optic toy lying around...
Too much difficult. Why not using a mirror screw like this:
http://www.televisionexperimenters.com/mirr_kit.htm
Old 12-15-2005, 03:49 PM
how would it be difficult?
Old 12-15-2005, 03:50 PM
that would be kinda hard to build.
Old 12-28-2005, 01:11 AM
vintagecollect's Avatar
Screw units require los of $$ for all the machining and other. If someone was to pony up dough, should set up to watch maybe TV programs since so expensive. Has an anyone built a LARGE unit as seen in some 1930's photos form Europe?? These can be made for higher reslution. Shame not to many made, I guess since so complex on optics alone and probaly were expensive=luxury items.
Old 12-28-2005, 08:58 AM
see
http://www.televisionexperimenters.com/mirscrws.html
