Hi Phil,
I would leave it as it is if the set works. Check the line output transformer for high currents and try to lower the cathode current of the line output tube to the lowest possible value. If you seal the transformer, there is no possibility for water which comes with the air into the coils, to dry out. - Eckhard |
