Old 06-15-2007, 03:05 PM
Mine's sheet metal, but very heavy sheet metal, & covered w/a vinyl woodgrain covering that is good enuff to fool you to think it really IS wood... No cataract, & this TV was stored for awhile in a damp basement..On inspection, the 1VP2 (?) tube was broken, & its socket crumbled in my hand, so I know at least THAT much is wrong w/mine. Looked like it had been way too hot several times.. Anyhow, I WAS impressed w/the general level of construction on this TV-Zenith stuff NEVER was "Cheap 'n' shoddy"-not at least while they were in Chicago.
Old 06-15-2007, 03:24 PM
tritwi's Avatar
tritwi tritwi is offline
zenith mad
metal cabinet
Hello Sandy and Compucat! Thank you for your kind replies! The Zenith has a very dark reddish cabinet, quite unusual for a television. It's all metal and everything seems to be made to last for decades.Unfortunately I will not be able to put my hands on it until July. I hope there will not be too many things to fix up. According to what the seller said to me, it belonged to an old man who died several years ago leaving it unused for ages. It was found in the attic when relatives sold the house. I ever dreamed about finding an attic full of Zenith stuff!!! Compucat, you're absolutely right! Two Zeniths are better than one and three even better but this one has been very difficult to find here (I had to offer 500 euro for it...) and I don't think I will soon find another! Do you know if this kind of set does work with vcrs and dvd players? Could it be retrofitted with a space command module?
Old 06-15-2007, 03:44 PM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
I have my Zenith connected to a combination VCR-DVD Recorder-ATSC Digital tuner. The only issues I have are that I get retrace lines from Macrovision copy protected DVDs but this will show up on most vintage TVs. Digital TV looks great on it and DVDs look even better. My set is not a remote model so I don't know about adding Space Command. The tuner I have hooked to my set has a remote so I only have to get up to adjust the volume and turn the set on and off.
Old 06-15-2007, 03:52 PM
compucat's Avatar
1949 Motorola 9VT1
Are you referring to the 1V2 focus rectifier tube? If so, I don't think that tube gets very hot. I'm surprised you would have a crumbling socket on that one. Are you planning to get the set going? I would love to follow the restoration progress on this forum.
Old 06-17-2007, 11:20 PM
Congradulations on an excellent find! It must feel great to find your first roundie, especially a zenith in Italy! A 24MC32 chassis is a 1965 model. Thats interesting that they had a pal converter. Since the TV was for pal, I bet the chassis number is slightly different as it was not for the US market.
As for the 1V2 socket crumbling, it does happen. Its not from heat, its from corona arc. The 5KV at the pin of the 1V2 tends to arc to ground. This results in carbon build and breakdown of the bakelite socket. On my 26KC20, I lost focus because the carbon almost completely grounded the 5KV. Ive seen this breakdown on two zenith roundies.
Old 06-19-2007, 12:32 AM
vintagecollect's Avatar
Old 06-19-2007, 06:07 AM
Kiwick's Avatar
Kiwick Kiwick is offline
slave to 3 equines
I bet the chassis of this Zenith was assembled in Italy (or heavily modified here anyway)... because apart from the PAL color system, the set has to work with our 50 hz mains and our 625/50 system
if i'm right, there are probably Italian glass-encased capacitors in place of black beauties and wax caps under the chassis.
Francesco
Old 06-19-2007, 06:22 PM
Old 06-20-2007, 06:52 AM
Kiwick's Avatar
slave to 3 equines
I think the flyback and the CRT's yoke (and of course the V and H oscillators) need to be different to work with our 15,625 hz horizontal and 50 hz vertical 625 line system.
Francesco
Old 08-10-2008, 11:06 AM
firenzeprima's Avatar
firenzeprima firenzeprima is offline
que trabaja pierde tiempo
Francesco
certainly all color TV set zenith which were sold on the Italian market were assembled in Florence by the company elettronica M. Montagni. boxes arrived with all the components and assemble them to Montagni workers , I remember seeing in years 70 to 80 boxes packed full of components now abandoned stock, but with the flood of the river mugnone went all lost. Curiosity .... many of the workers who worked in assembling the Zenith color TV now working as technicians television in some Italian TV. in attach pic of mr Montagni, tv color Zenith in Montagni office, (1978) and Montagni building
fernando
