Charles
Collecting & restoring TVs in Los Angeles since age 10 |
Hawkeye Picture Tube does excellent rebuilding work. I had the 21FJP22 in my Zenith roundie rebuilt and the set performs like new. It's not cheap, about $400 with shipping but well worth it if you plan to keep your set and use it regularly like I do with my Zenith. Please post some pics. That RCA sound great. I love the big roundie combos with the solid wood cabinets. I just wish I had the room for something like that.
Just look at those channels whiz on by. - Fred Sanford |
I found a good 3A3 and a 6BK4 in my collection today, im going to install them tonight with all the other weak tubes and attemp another power up on the variac. Lets see what happens! Ill post some pics while im at it.. Hopefully ill snap a pic of the set in action!
SHES RUNNIN!!!
Well I got a blurry raster, focused, looks better, Green lookin, so I adjusted screen controls. adjusted everything the best I can, brought back proper greyscale. picture a little dim, not much, added brightness causes blooming, there is color, washed out looking just a bit, I still have weak tubes, im in need of a 6GM6 (2nd pic IF), 6KA8 (AGC noise & sync sep), 6EW6 (burst amp), two 6GY6 (x&z demod), and two 6GU7 (RGB blankers), these tubes test bad, and some borderline. Im wondering if this could be a cause for faint retrace lines, I still cannot find my picture tube tester... Last edited by freakaftr8; 09-26-2007 at 02:50 AM. Reason: fixed problem |
That's good news! I bet that some of that dimness is the cataract. Not a BIG factor, but every bit will help.
Blooming (picture gets BIGGER and dims from the center outward when turning brightness up) is caused by several things: First one I'd check is the filter caps. If they leak, your B+ is low, and the set will bloom. Also the 3A3, and possibly the damper and horizontal output tube will cause that. If it's just BLURRING with increased brightness (pic stays pretty much the right size), it's probably a gassy, weak CRT. Depending how bad, you can either add a brightener or even rejuvenate it. I wouldn't rejuvenate it though, unless/until you're willing & ready to have it rebuilt. Usually rejuvenating a 21" roundie is fine for about a year, but there's always a good chance that you'll kill it on the spot. Do you have a high voltage probe? If so, measure the HV and see if it's dropping off when the picture blooms. It should drop slightly, but stay over 20KV or so. MY ADVICE: DO NOT INCREASE the HV adjustment!!!!!! Every time I've done that, the flyback has failed on me within a month, even if I'm just turning it up to where it's supposed to be!!!!! If the HV is low, leave it. If it's high, turn it down to 21KV. Charles
RCA roundie
Hey Charles, No this set I found in the San Fran craigslist, I drove 150 miles from my house to get it, and it was worth every mile.. I just wish I could figure out this pic posting thing to show you guys the set! |
Charles
