Old 09-29-2007, 09:08 AM
Njord Noatun's Avatar
Njord Noatun Njord Noatun is offline
AK Member
Originally Posted by Thyratron View Post
I had the radio apart the other day, trying to retension/clean the headphone jack, as the plug fit is very loose and makes a poor (or no) connection. "Trying" is the word there, as I was unable to reach it easily, and did not want to be taking the circuit boards, speaker, etc. apart just for something like that. Does anyone know of a trick for doing this from the exterior of the jack? It's a regular 1/8 incher, or so I assume; Njord, please correct me if I'm wrong and it's a different standard that was used.
Again, Per Arne at AA says that although he believes there are two standards for the the 1/8" (3.5 mm minijack) jack (one US standard with a pronounced "waist line near the tip, and one International standard with a straight(er) tip), both types should fit equally well. He also notes that there is no point in connecting a stereo plug - a mono plug suffices.
Specificallty to your question, he says that it is possible to tighten the springs inside the headphone connector with a screwdriver for a tighter fit, but that it is done from the inside and some disassembly is required.
Hope this helps.
Njörðr Nóatún
Pioneer, Tandberg, Yamaha, Concept, Rectilinear, ADS, Advent resources.
Contribute scans to [email protected]
