Old 03-31-2004, 07:03 AM
Chad Hauris's Avatar
You might try a 12AX7 or 12AT7, 12AY7, etc. just for testing purposes, I think they all have pretty much the same pinout as the 12AZ7...
Old 03-31-2004, 07:59 AM
ChuckA's Avatar
ChuckA ChuckA is offline
Direct sub is a 12AT7, also a 12AU7.
Chuck
www.myvintagetv.com
Learn from the mistakes of others -
You can't live long enough to make them all yourself.
Old 03-31-2004, 08:13 AM
Kamakiri's Avatar
Kamakiri Kamakiri is offline
If a 12AU7 will work, then I'm set. Back at it this evening
Old 03-31-2004, 06:14 PM
Kamakiri's Avatar
Getting better, now I think it's probably a matter of adjustment or calibration somehow.....
Old 04-02-2004, 09:08 PM
Kamakiri's Avatar
Decided to set the tester aside, and rip the VCR with on-screen menus out of the living room.
Seems that I only made things a bit worse, which is no big deal, but I notied that 2 or 3 of the controls (one was for blue convergence, where I have a problem) have absolutely no effect when turned. Is it possible that I have a bad convergence board?
Old 04-02-2004, 10:34 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
I would check the caps/resistors on the board. Should be pretty easy since you can pull the board and set it on top or maybe on a chair near the rear of the set. Also, try spraying some cleaner in the controls.
Charlie Trahan
Old 06-19-2004, 10:16 PM
Kamakiri's Avatar
Free to good home......come and get her
I just really need the space!
Old 06-20-2004, 09:02 PM
gosh darn it, one of us lives too far away!
