If it's actually a field coil speaker, the circuit may need an inductor to replace the coil when replaced with a PM speaker. Might check the DCR of the speaker too. Speaker impedances on those old transistor radios were all over the place back then. I wonder if the existing speaker is actually an output transformer and driver built together? Many of the old transistor radios used OT's.
Let me live in the house beside the road and be a friend to man. |
Sony Trinitron Fan |
It is a speaker and output transformer combined. As the loose transformer lamination moves, it modulates the speaker cone. GE also used that concept on some early paging receivers. The communication engineers took the idea from the consumer guys as a cost and weight measure.
Try passing the entire speaker assembly through a color TV degaussing coil or some other strong AC field while shaking it, to release the filings. You may not even need to remove it from the radio. |
