Old 01-31-2008, 07:32 PM
ismael-1986 ismael-1986 is offline
AK Member
Just need a little help please read !!!
Hi people, firstly im sorry if ive posted in the wrong section but i need some help on my modern panasonic crt ? if im in the wrong catagory again i opolagise but BADLY need some help on it ! thanks
Old 01-31-2008, 08:36 PM
MRX37 MRX37 is offline
This is the EARLY color television forum, but you're close enough I guess. If not, a mod will move the topic.
The more info you can give us on your TV, the better we can help. See if you can answer these questions:
What model is the TV?
What problem or problems are you having?
What have you tried, if anything.
Old 01-31-2008, 10:10 PM
AK Member
firstly im from the uk so obviously im using a 5ohz pal tv
its a panasonic tx-36PG50 36 inch 15:9 crt
the problem is from new and ive seen this problem been stated on other forums is that the tv speakers hum which in av mode, its not a faulty capacitor as it did it from new and other people with the same tv have had the same problem, i heard there was a simple earth wire fix to it but never found any more info on that hence on here, its more of a faint whistle than a hum that has always been annoying and also i cant use the the internal sub cos that makes a sort of MMMMMMM sound more like a hum !!!
please id be very greatful if someone out there cud shed some light on this !
thanks
Old 01-31-2008, 10:12 PM
AK Member
ive disconnected the speakers and sub changed and even stripped the whole chassis but still no change ??? and its 16:9 not 15 sorry
Old 01-31-2008, 10:54 PM
I don't know much about PAL TV's, nor what could be causing your issue, but until you get an answer, maybe I can offer you a workaround solution: It'd be a kludge until you can get a better answer, but it might work:
If possible, use a VCR or something with a tuner and video output on it. Run the video through your TV, but run the audio through the VCR, and connect the VCR's audio outputs to an amplifier and speakers.
Old 02-01-2008, 05:38 AM
AK Member
to much of a hassel i really need some answers here lol its a gr8 set
Old 02-01-2008, 11:34 AM
Just ideas: a cable inside the set is out of place, causing intereference to something in the audio section. With the case opened you could try moving some wires around and see if it changes anything. Possibly could be a bad solder joint or otherwise poor connection at the inputs?
