Old 03-13-2008, 10:39 AM
I've had to clear up (or, try to clear up) several issues with some people.
1. Just because you have a HDTV does not mean that you are viewing the program in HD. A lot of people seem to think that everything will be HD by 2009. The over the air broadcast has to be digital instead of analog but does not have to be HD.
2. There is no need to trash your old set just because things are going digital. An OTA converter will make the old set work just as well as before. I've talked to several people that bought expensive flat screen TV's because they were made to believe by dishonest sales people that their old TV would be worthless in '09.
3. I've had a few people think that the only TV's that will be effected will by old rotary tuner sets since these are the types of sets that are usually seen on the DTV transition commercials.
4. And then, there are the totally clueless people that will be in for the shock of their life when analog gets turned off. That will be the day when we really hear screaming.
