Old 03-16-2008, 11:57 AM
kx250rider's Avatar
REAL TVs have TUBES!
Those Sanyo/Fisher sets are loaded with ceramic mini-modules, which have primitive foil-side mounted components. You might try tapping each one and see if you find a bad connection. If so, you can unsolder and remove the mini-module, and resolder all the connections on it carefully. Those caused a lot of audio and CRT drive problems. Also, the table model stereo Fishers with speakers mounted on the sides of the cabinet had problems with the speaker foam surrounds dry-rotting and ripping apart.
Charles
