Old 07-07-2008, 02:36 PM
electroking's Avatar
a- v- karma member
Originally Posted by yagosaga View Post
The Sovjets used 220 Volts, 50 Hz. Due to the lack of suitable television valves, they used different filaments voltages. That's the reason for the large mains transformer. The horizontal frequency is 8,575 Hz. Video bandwidth is appr. 1 to 1.5 MHz.
EHT is generated in the line output circuit, but there is no damper.
- Eckhard
The double diode with both plates tied together (at the bottom right
of the schematic) looks like a damper to me...
Old 07-08-2008, 08:14 AM
yagosaga's Avatar
yagosaga yagosaga is offline
VK Member
I have seen that. But I am not really sure about it. The damper usually is connected with the primary coil, the other end is connected with the plate of the line output tube. This "damper" here has an own coil. It looks like a limiter. But the function of the damper is also to increase the plate voltage of the line output tube.
I have taken a look at the schematics for the Sovjet peoples tv set, the KVN-49. There is absolutely no damper and no double diode.
Kind regards,
Eckhard
Old 09-04-2008, 04:23 PM
Telecolor 3007's Avatar
I love old stuff
In Romania you can find a "KVN"-49 at Iashi.
Sailor Moon
