Old 07-07-2008, 04:34 PM
Got High Voltage? Easy test
You can use a Compact Florescent to check.
Old 07-07-2008, 10:24 PM
kbmuri's Avatar
kbmuri kbmuri is offline
Brilliant!
Do not attempt to adjust your set.
Old 07-07-2008, 10:35 PM
devoid's Avatar
devoid devoid is offline
NA Volvos and Amplifiers
Will that work with DC also? Or just from capacitive coupling with AC? I think I know the answear but wonder what experiance knows.
What I don’t want is music that was written to be recorded.
Old 07-07-2008, 10:58 PM
Pretty sure it's AC only, it works from the Flyback to the middle of the HV rectifier tube but shuts off as soon as you get to the DC side.
It'll sometimes light a little on the 6BG6 output tube too.
Old 07-08-2008, 09:27 AM
PaulOF's Avatar
PaulOF PaulOF is offline
I find that if you use a fluorescent tube, ground one end of it, and bring the high voltage anode clip close to the glass in the middle of the tube (not the other metal end of the tube) it will light it. It has to be nearly touching the tube.
Paul
