Old 08-10-2008, 06:46 PM
Kiwick's Avatar
Kiwick Kiwick is offline
slave to 3 equines
Philips roundie!
Hi you all
have you ever seen one of these?
This is the 1964 Philips 21KX100A, chassis K4, probably the only European round color set that was actually available for the public to buy
This was actually a hybrid set, as it had a tube NTSC chassis and a solid state PAL converter
http://www.marcelstvmuseum.com/photoalbum30.html
Old 08-10-2008, 07:26 PM
Dave A's Avatar
Dave A Dave A is offline
A quick translation from Babelfish, photo-by-photo. Some words not translating. My entries in lower case.
Front of set: PRODUCTION 1964 PHILIPS 21 KX 100 A/04 CHASSIS. K4 SCREEN, 21FBP22 OR AX53-14. FLOW USAGE 380 WATT. WEIGHT 72 KILOGRAMMES.
Rear of set: IN CANADA SELLS PHILIPS IN 1962. ALREADY KLEURENTV' S FROM SERIEPRODUKTIE. AFTER A TIME OF TO EXPERIMENT, STARTS PHILIPS IN 1964, WITH OWN TEST RETRANSMISSIONS. FOR THREE YEARS IS END. COURTS THE ONLY CITY IN EUROPE WITH OWN COLOUR TELEVISION.
Rear interior: TO MAKE MAKELIJKER REPAIRING, YOU CAN THE CHASSIS TO FRONT SLIDES OUT PHOTOGRAPH RECHTSBOVEN: THE SCREEN PUTS STILL A COMPLETE END BEHIND FROM THE CUPBOARD. THEREFORE ALWAYS PAY ATTENTION WITH TRANSPORT OF THE TELEVISION.
Under chassis: LOWER PART OF THE CHASSIS. ADVANCEMENT OF CHASSIS COME WORRY ABOUT STILL FROM 1950S. ER DELICATE CONDENSERS STILL SOME
CRT neck: 70 DEGREES AFBUIGING FOR THE SCREEN, 21FBP22 OR AX53-14
HV cage: HOOGSPANNINGSKOOI WITH FAIL 2 X PL500, 2 X PY 88, 3A3, DY 87 AND 2 X PCF 80
PCB board: THE TELEVISION HAS BEEN MADE OF ORIGIN FOR NTSC TV RETRANSMISSIONS. NTSC IS AMERICAN UITZENDNORM IN THE NETHERLANDS ONE WILL USE STOP SYSTEM, AS A RESULT OF WHICH PHILIPS IN THE NETHERLANDS PRINTS A STOP BUILT IN
Tuner: KANALENKIEZER (tuner) SITS BEHIND SERVICE PANEL. THE TUBE ABOVE IS COORDINATES EYE
CRT out of set: THE SCREEN OF PHILIPS 21KX100. THE SCREEN IS ENTIRELY ROUND AND THE RING OF THE SCREEN IS ALMOST 5 CM THICK. THIS IS AX53-14 A SCREEN.
Dave A
Old 08-11-2008, 12:18 AM
Tony V's Avatar
Tony V Tony V is offline
What a neat set! Thanks for sharing it with us.
-Tony
Old 08-11-2008, 12:38 AM
OvenMaster's Avatar
DTV blows
That entire site is just incredible. Compared to American TVs, lots of those Euro sets look quite strange to my eyes.
Tom
Tom
Old 08-11-2008, 06:01 AM
Wow....Just "Wow..."
