Old 10-26-2008, 07:48 PM
Ex-Philco
The correct CRT is available. That's good news.
If that does not work out, you can light a 6 volt tube by moving the filament connection from the 2.7 volt tap to the 6.3 volt tap on the power transformer. The transformer will handle it. Earlier versions did not have the tap and powered the CRT from the 6 volt tap through a dropping resistor.
