Old 11-20-2008, 03:08 PM
toxcrusadr's Avatar
toxcrusadr toxcrusadr is offline
Originally Posted by markdi View Post
would a multi meter really put out the current to blow a tube filament ?
That particular tube, yes, it could. Some of the battery powered VOMs use a 9V battery, for example.
Summer's here and the time is right.
Old 11-20-2008, 04:27 PM
markdi markdi is offline
markdi
I think the series resistance of the meter and the meter movement would limit the current to far less than a quarter amp.
Old 11-20-2008, 09:23 PM
Fisherdude's Avatar
Fisherdude Fisherdude is offline
The Golden Age of Hi-Fi
A VOM only puts out current when it is measuring resistance. Since the circuit must be de-energized when measuring resistance, and you need a source of current in order to measure the voltage drop across the resistor, the VOM/VTVM/DVM/DMM provides it.
The amount of current used is miniscule, and it's highly unlikely you could cause damage with it, unless you're trying to measure continuity through your PC's chipsets. The battery used to power the multimeter is NOT passing that full voltage through the probes.
I may be growing older, but I refuse to grow up.
