Old 12-13-2008, 12:27 PM
fltyrap's Avatar
fltyrap fltyrap is offline
AK Member
Resistor Watts?
Hi Everyone,
So I replaced a selenium rectifier with a diode and dropping resistor on a Zenith C845 (thanks everyone for your help with that), and I flipped the thing on.
Everything was fine, until after about three seconds I noticed smoke from the chassis. Inspection revealed the smoke was coming from a resistor-- a 680 ohm resistor. I guess that sucker is fried.
My question is, how do I determine the watt rating that I need to replace it with? The schematic just says, "680". The resistor leads into a 6BJ6 R.F. tube, and says "98v" at the input.
I suspect I should be able to figure this out from the schematic, but I'm not very good at reading these things.
Old 12-13-2008, 02:46 PM
gadget73's Avatar
gadget73 gadget73 is offline
Usually its a 1/2 watt resistor unless otherwise noted on the schematic. Many schematics actually say that somewhere on them. What you'll need to look for is why the resistor failed. Often its a shorted capacitor or something, resistors don't fail on their own like that.
Random bits of stuff in the collection:
Yamaha YP-D4 turntable with B&O MMC 10E cart
Allied 495 receiver
2 Magnavox amps, AMP150 and an AMP178, currently under the knife.
Onkyo TX-4500
Onkyo Radian III speakers
Old 12-13-2008, 02:54 PM
fltyrap's Avatar
AK Member
Thanks, Gadget. There must be a short somewhere because I replaced it with a 1/2 watt and the thing fried instantly. I guess in that case I should proceed with recapping and see if that solves it.
I have read that it's good practice to check that the radio works after each capacitor is replaced, but if something is frying that doesn't seem wise.
Old 12-13-2008, 06:02 PM
gadget73's Avatar
I would start with the capacitors on each end of that resistor that failed, and go from there. I can't locate a schematic for that model, but if you've got one I may be able to suggest what caps to start with.
Allied 495 receiver
Onkyo TX-4500
Old 12-13-2008, 09:59 PM
eufaula1 eufaula1 is offline
AK Member
I think he may be talking about the resistor (R3 on some schematics, R2 on others) that feeds the screen grid on the RF tube. I wonder if the B+ voltage might be too high after the rectifier change out?
Old 12-14-2008, 09:02 AM
fltyrap's Avatar
AK Member
Hi Gadget,
The schematic is online at http://techpreservation.dyndns.org/s...ics/Zenith.htm -- it is chassis # 8C02 in the drop down (if you have the djvu viewer-- if you don't I can scan my paper copy and send that).
The resistor is the 680 ohm heading into the 6BJ6 (into the screen grid I think, as eufaula1 suggests).
I was also wondering if the silicon diode is providing too much juice. I put a 50 ohm, 10 watt dropping resistor before the diode, but maybe this isn't enough? I had some people say 50-100 ohms would suffice, and others say no resistor at all was needed.
