Old 01-05-2009, 03:47 PM
AUdubon5425's Avatar
CTC-12 on eBay
no affiliation...
Interesting CTC-12 with pushbutton tuning on eBay. Works but it looks like it needs a lot of attention. I don't think I'm experienced enough yet to take this one on...hopefully someone will save it.
Go to eBay and enter item number 280299404397 in the search box. (The url is ridiculously long)
AUdubon5425 Youtube Channel
Old 01-05-2009, 05:14 PM
Adam's Avatar
Adam Adam is offline
http://cgi.ebay.com/ws/eBayISAPI.dll...0%3D%26fvi%3D1
It looks to be a remote set.
Old 01-05-2009, 05:28 PM
Wow...The CRT plug-end cap is hangin' on by a prayer...
Old 01-05-2009, 06:23 PM
Bill R Bill R is offline
This is the set that was offered for free on craigslist. I emailed the original owner and they said it was gone. Guess I know where it went now. That CRT base would make me nervous too.
Bill R
Old 01-05-2009, 06:39 PM
Bill R
I said the same thing before I got to your post. I guess that answers my question. That tube can be fixed with another bakelite socket. It is however very tricky to get the wires into the new pins. With some time and a LOT of patience, it can be done.
Old 01-05-2009, 07:06 PM
ohohyodafarted's Avatar
Bob Galanter
Really not all that difficult Mark. Use the John Folsom method. You tack solder a 3 inch length of fine copper wire to each of the wires on the crt. Then you use the extension wires to "thread" the crt wires into the pins. Works like a champ. When you have positioned the new socket and taped it in place, and are soldering the wires in place, you can just pull the extension wires out as you solder. Try it next time!
Bob
ME http://AntiqueTvGuy.com
Old 01-05-2009, 08:50 PM
Thanks Bob!
Old 01-05-2009, 09:06 PM
Dave A's Avatar
Dave A Dave A is offline
And if you make each one of the extensions longer than the next by a bit, you can thread them one at a time going along as they get shorter. Choose your extension length.
Old 01-06-2009, 06:20 AM
firenzeprima's Avatar
firenzeprima firenzeprima is offline
que trabaja pierde tiempo
that sin is too far for me
Old 01-08-2009, 08:52 PM
JB5pro JB5pro is offline
Somebody's very lucky!
I like that channel knob cover. Never seen that. I didn't know that frame design had a ctc12. I bet the CRT is not the original phospher color. Looks like alot of tlc will make a great set for Aunt B's living room.
I guess a repairman who was trying to save the flyback threw the HV cover away. That may be hard to find.
