my very first vintage TV!!
May God have mercy on yr soul...Yep, re-cap, & check resistors, if the CRT's good, it should be a doable project.
Benevolent Despot |
Hey! welcome to the TV forums! And now that you're bit by the bug, kiss any available space in the basement goodbye! It comes on slowly, one day you notice that there isn't room to breathe. LOL. BTW, I should have that Moto manual out soon, I've been pretty busy lately so please bear with me. Do like Sandy said and she should come back to life. Although these 'ol sets can be cantankerous little f*ckers from time to time.
Fairchild. ---VERY--- cool find. I came up with something similar years ago, though I don't think it's a Admiral. RCA or GE maybe ?? Pic attached.
thanks Zentih, SAndy and Ohigh... I like it so much that it'll be an art object if it doesn't work... but are CRTs ever available or fixable? The rest I can handle...
Ohigh... be that a Fisher 50A that I spy thar, next to the Dynaco ST-70!! ? I LOVE that turquoise TV... my favorite color (I have a 58 DeSoto!) ... I think these cool little 50s portables might be my TV niche... I know what you mean about space, I dabble in stereo consoles a bit, the 5' long kind. Yikes!! Roger in NY |
If you're gonna' do TV, then the little portables might just be the way to go. They don't take up scads of room like the consoles! 58 Desoto? One of the lost marques..... And for sure Chrysler had the wild 50's look going full bore right about then. |
My very first eBay purchase was one just like this! now it's 12 years and 100 sets later...
![]() These are really quite easy to work on, PC board construction makes recapping simple, the CRT is probably good, most of these little sets don't seem to have had as much use as their bigger cousins. I have a schematic but it's a copy already and would be difficult to copy again. The Sams Photofact# for this set is a 350-1 |
Welcome to the addiction.
Dan |
Congratulations! It is cute. It's strange how inanimate objects can intrigue us.
John |
".... 12 years and 100 sets later." Uh oh!!!! What have I done?!! I love this thing!
Replace those Selenium rectifiers!!!!
Don't forget, you will have to add extra resistance before the first filter, or, you will blow your power supply with the new, more efficient silicon rectifers. I reccommend The 2Amp, 1KV diodes due to the surge factor. Lave seleniums there for show, but, completely disconnect them. You'll need new electrolytics as well. Welcome to insanity 101. 47 tv's later, and, three more coming? Bill Cahill
"Tubes are those little glass things that light up orange unless there is a short.. Then they light up all pretty colors..." Please join my forum. http://www.tuberadioforum.com/ |
Bill and Eric, do you have 47 and 100 sets respectively still in your possession?
In any case, WOW! John |
Yep.....
![]() ![]() ![]() ![]() :hu ge:![]() ![]() ![]() ![]() Bill Cahill
"Replace those Selenium rectifiers!!!!" yep, I figured so, gotta do it in all the '60s Fisher and other units that have em... I kinda like the tube recitfers of the older days.
I know about Predictas, but are there small portables that are especially unique or cool worth looking for? |
It's hard to say.. In 1959 Admiral made one neat looking 17" slimline portable that came in some neat color combinations, and, once, I even worked on one with factory installed UHF. Plastic front, and, back covers.
However, negative poits follow: Low life expectancy picture tube. Yoke often dis intergrated due to plastic disease. Cabinet was a shock hazzard. Front screen got static charge from hv, and, was a shock hazzard. So were the old GE tv's. On the M4, 5, 6 GE's, plastic mask, with gold paint on GE's got one heck of a hv static charge. Touch that, you got many surprises..... The Admirals had problems with poor connections on the circuit boards, as did the GE's. The old top hat rectifiers in the old sets were a problem with high leakage, and, shorting out. Circuit breakers usually didn't hold up, either. When they worked correctly, the Admirals received fairly good. I would pass on any of the early Silvertone console, table model, and, portable tv's from that era up to 1965. They wre lousy sets, hard to work on, broke down considerably, were dangerous to service, and, broke down often. Vertical chassis, one side of line on chassis, all hot connections for line, b+ boost, filters, rectifiers, hot line, etc., were in easy access. The tubes were pointed to front of set. You had to reach in a tight area to get at tubes. Chassis tilted backwards. Then, was a nightmare to get back in. We HATED those sets!!!! RCA '59 models had a neat look, but, quality tended to be low. They performed poorly. And, the channel selector knob was metal. On early versions, it went directly on metal shaft. Chassis was one side of line, and, made this a shock hazzard. There was one similar model with a power transformer. The hump top 14"-17" "deluxe" portables were neat looking, but, were a repairmans' nightmare. The larger size with a vertical chassis had a power transformer, and, weren't so bad. Bill Cahill
