Old 01-11-2005, 03:56 PM
mbates14 mbates14 is offline
Talking Another color roundie saved!
I saved my first color roundie!
The story:
A friend of mine called me up on the phone, saying he found an old tube TV in the trash down the street from his house getting rained on. He pulled the tubes, and said do you want the tubes? or do you want me to get the whole TV, and he said that the picture tube looked broken, so thats why he didnt get the whole thing.
I told him to get the whole thing. So, I thought it was an old black and white 19 inch console, or something like that. didnt have my hopes too high.
Anyway, He came over the next day. and as soon as I looked out the door, I about fainted and fell to the ground. It was a zenith, console roundie color TV with a 21FBP22 CRT, no cateracts, or blown phosphor.
My first roundie! Now, I investigated the CRT, and the socket base is crushed into 3 peices. I looked real closely, and NO damage to the GLASS!! Which means the vacuum hopefully is still intact.
But, its pushing me away from it, because it has a CRT brightner hangen down on it, which comes to tell me the CRT is weak, if not dead.
I need the sams and the CRT pinout to test the heaters, for vacuum, and if they are open.
The pins are still intact, but the base is crushed, and I few wires are loose in the chassis.
It is a Zenith color TV, has no back, and the chassis number is: 24NC31Z
I will post pictures when I get batteries for the set.
Well, at least this set was saved from either getting munched into peices by a garbage truck, or getting woodchiped by rain, or turned into a fishbowl.
(I hope the CRT is good, because if not, the project will be condemmed).
And I saved it just in time for these punk kids with a baseball bat that were going to bash it in right before the frined of mine pulled up to get it.
Old 01-11-2005, 04:32 PM
Attaboy !! Good for you ! You done a good thing, even if you end up trashing it-you at least tried. Lets hope the CRT is still good.-Sandy G.
Old 01-11-2005, 04:58 PM
i need a pinout of the crt, and the sams if someone is willing to share....
pretty please with sugar on top
Old 01-11-2005, 05:24 PM
Lucky find! 24NC31 is the last roundie chassis zenith made, 1966. Look forward to seeing the pics
Old 01-11-2005, 06:14 PM
I managed to get the socket back on the tube, there was 1 broken connection between the socket and the glass, and it happened to be the green cathode, I tried to solder it, and I put the socket on carefully, and lets hope it stayed on tehre, and not popped back off.
Well, when I get the chassis working, and if the tube so happens to be still good, the green will be missing if that popped off again.
I hope not, because that socket was a b!tch to put back on.
Old 01-11-2005, 06:42 PM
Pics
Old 01-11-2005, 06:56 PM
I have a good question for you, Where in the blue blazes of heck is the power switch and vol control???
I cant turn the blasted thing on. lol.
Old 01-11-2005, 07:29 PM
CRUD!!!!!!
The CRT is gonde.
i can tell this, because I fired it up on the variac, there is high voltage, and there is a wierd smell throughout the set, not fried component smell, but something else, like a rotten egg smell.
Anyway, I looked at the gun of the tube, the filiments light, BUT there is constant blue/purple arc between the cathodes, and the other electodes, and you can see a constant blue stream down the entire gun in the center.
This is a bad CRT isnt it?
i let it run for a bit, and now the HV is gone.
Because if it is, its going right back out into the trash.
I cant afford another CRT. aint gonna happen.
Old 01-11-2005, 07:31 PM
reeferman's Avatar
As I recall, the on/off/volume came through the center of the UHF knob. But then again, I might be having a flashbact to the '60s.
Old 01-11-2005, 07:44 PM
GAGGAAAAAAAAAHHHHHHHHHHHH!!!!!!!!!!!!!!!!
Dam, my life sucks.
pop. goes the filiments in the CRT. Means No Vacuum.
crap crap crap crap crap crap.
Just when I thought I had something, im back down to nothing.
Old 01-11-2005, 07:46 PM
just for the hell of it, I popped off the vacuum seal stem in the back, and nothing. nadda. no vacuum. it leaked off over time. SHNIZER.
Old 01-11-2005, 08:04 PM
Well, how much does it cost to rebuild one of these?
Can you find used ones anyware?
Old 01-11-2005, 08:07 PM
Chad Hauris's Avatar
Yes, the volume/power is usually through the center of the UHF knob on this age of Zenith. Don't be too discouraged about the bad crt...I found one where the CRT had lost its vacuum but just a little bit earlier found a round set with bad flyback...so was able to make one good set out of the two.
Don't trash that chassis...just be on the lookout for another set, which may turn up easier than you think.
I think it costs about 175.00 for a rebuild but you may not be able to rebuild one that's aired out. A salvage CRT from another set is likely your best bet.
Chad Hauris
Old 01-11-2005, 10:09 PM
peverett peverett is offline
Are you anywhere near Austin, Texas? I have a couple of the 22FBP22s in the garage that I will give you if you are. These both have vacuum.
I also believe that the emission is ok.
