Old 03-19-2009, 05:39 AM
I would be more nervous than a cat in a room full of rocking chairs tryin' to work on that bad boy...
Old 03-19-2009, 06:58 AM
yagosaga's Avatar
yagosaga yagosaga is offline
VK Member
This is the raster which appears on the screen without an antenna signal. I have got the same raster before I tuned in the channel.
Old 03-19-2009, 08:04 AM
tubesrule's Avatar
tubesrule tubesrule is offline
This is an interesting observation Eckhard. Looking at the schematic it appears that the line and frame oscillator stages use blocking oscillators, so I would have expected the set display a normal blank raster. What do you think is causing the displayed raster to look like this when no signal is present?
Old 03-19-2009, 01:29 PM
yagosaga's Avatar
VK Member
The height of the synchronisation input level can be controlled by the 5 K control at the cathode of the oscillator tube. My experience is, when I have adjusted the sync level for best synchronisation, and I draw the antenna plug, the raster looks frazzled.
