Old 04-05-2009, 11:14 AM
BostonDave's Avatar
BostonDave BostonDave is offline
AK Member
Help with old Auto-Lite Capacitors
I have a 1930's Rogers-Majestic (made in Toronto, Canada) Console Radio Type 6M631. I haven't had any luck finding any mention of this model on the internet anywhere. No specs, no schematic diagrams, none for sale, not a picture. I'd like to do a recap and I've managed to read the values from the actual caps for 8 out of 11 of them. The last three are 2 inch axials made of paper with well sealed resin? ends and have nothing on them except 'Auto-Lite', 'Tiger' and a 5 digit part number (each one has a different part number). I'm guessing they were added at some point.
Is there any way to determine the value of these through looking up the old Auto-Lite part numbers somewhere? I haven't found anywhere yet.
If not I'll probably end up leaving them in and hoping for the best rather that guessing at the mf values for them.
Old 04-05-2009, 03:24 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
Even though they probably need replacing, they might still be good enough to test for the capacitance value if you have access to a capacitor tester.
You might also post your question on www.nostalgiaair.org if you haven't already. Although the noise level is a bit high over there, there are quite a few knowledgeable people. They might point you to a schematic also.
John
Old 04-05-2009, 06:20 PM
BostonDave's Avatar
AK Member
Thanks for your reply. I do have a capacitor tester on my digital multimeter, but I wasn't sure if it would use enough voltage to get an accurate reading from one of these old caps which are used to having 400-600v through them.
I also posted over in nostalgia air so I'll see what happens over there.
Old 04-06-2009, 10:40 AM
BostonDave's Avatar
AK Member
Looks like Justradios.com has a schematic for this radio. It should be arriving in the mail soon.
