Old 07-18-2009, 10:13 AM
Oerets's Avatar
Oerets Oerets is offline
AK Subscriber
Knight Star Roamer INFO !
Pick up a Knight Star Roamer yesterday at a tag sale , seems to be working somewhat OK . On opening it up noticed that there are two connections loose .
Plus the 6BE6 and 6AK6 both tested weak almost bad on my tester . Can't find my sub book for tubes right now so they will have to wait till ......
I'd like to see if anyone can help me out and give me a clue as to were the two wire go . One is off a cap and I think it should go to chassis ( on closer inspection it looks like it should go to the switch above it ) the other one is the might be for the key (morse practice ?) .
Wanted to get some good input before just connecting anything up .
Also how good would a old whip antenna from a CB work with the unit ?
Barney
Marantz 1070 4060 2218 2240B 2250B
Pioneer SA 7500II Carver M200t's
Denon TU's 550 450 Superscope T220
HK 2500,CD191
Sony CDP players 23,191
Marantz 6300 Harmon Kardon T 20 Grado RS-III, 3E+
AR's Advents BA's Marantz Polk Tony Gallo....:music:
Old 07-18-2009, 09:26 PM
Oerets's Avatar
AK Subscriber
HK 2500,CD191
Old 07-19-2009, 12:23 PM
12J5's Avatar
12J5 12J5 is offline
AK Subscriber
The following URL is for the instruction manual for the Star Roamer which will show the connections for the radio:
http://bama.edebris.com/manuals/knight/str-rmr/
A random 25 to 100 ft. wire run outdoors will serve fine as a substitute for a CB antenna.
If your 6AK6 and 6BE6 tubes are defective, Electron Tube Enterprises (www.etetubes.com) is a good source for replacements.
Old 07-19-2009, 01:07 PM
Oerets's Avatar
AK Subscriber
I tried to download the manual , all I get is the schematic ...
Was able to figure out the connections last night . The tubes seem to be working fine for now .Thanks for the help ...
Barney
HK 2500,CD191
Old 07-19-2009, 01:37 PM
mhardy6647's Avatar
mhardy6647 mhardy6647 is offline
I just downloaded a 36 page PDF; here's the link:
http://bama.edebris.com/download/kni...rmr/strrmr.pdf
PM me if you cannot manage to D/L a copy; I can e-mail it to you.
all the best,
mrh
Old 07-19-2009, 02:46 PM
Oerets's Avatar
AK Subscriber
Fixed the problem with the manual download after even an e-mail would not open correctly .
Re-installed adobe and it worked !
Thanks again mhandy6647 for all the help ....
Barney
HK 2500,CD191
Old 07-19-2009, 08:00 PM
Oerets's Avatar
AK Subscriber
Here's a picture just before going on the shelf ...
Barney
HK 2500,CD191
Old 07-19-2009, 08:09 PM
12J5's Avatar
AK Subscriber
Looks good! How's it working?
Old 07-21-2009, 09:37 AM
Oerets's Avatar
AK Subscriber
So far it's doing great , just a scratchy pot that might need to be replaced .
Seems to pull in stations on most of the bands , need a longer antenna to be sure .
Not much of a AM talk radio fan ........do like the international station though .
Barney
HK 2500,CD191
