Old 09-24-2009, 09:36 PM
Originally Posted by avalon1308 View Post
Hi,
I have the exact same one, it is a ctc 10 with an FBP in it. it did have the bearing of the channel selector broken but glued it back with super glue and working fine ever since although not changing the channel too often, only to give it some movement. Very heavy but a beautiful piece. Lately it started having some hor sync stability probs but still watchable. great set for a collector
Does the -10 use the dual diodes in the horiz circuit, like the CTC-11? On my -11 I was having trouble with a very touchy horiz hold, and eventually it wouldn't sync at all. New diodes (I think I had a NOS dual) fixed it right up.
Old 09-25-2009, 02:54 PM
ohohyodafarted's Avatar
Bob Galanter
I own a CTC10 Remote, early american maple and it is like the day it came off the line at RCA. I paid $50 for it. Has the original 21cyp and it tests like new.
I made this guy an offer of $100 and he turned it down. He is delusional if he thinks he is going to get big bucks for it.
ME http://AntiqueTvGuy.com
Old 09-25-2009, 03:14 PM
avalon1308 avalon1308 is offline
I think I paid 50 dollars for mine from craigslist. I recapped it and it worked fine for many hours then, I heard a little spark in it and since that, it has that sync problem. Thanks for the advice, I will check the diodes
Old 09-29-2009, 09:04 PM
I LOVE that set
Old 10-05-2009, 08:38 AM
This did it, I replaced the diodes and it works fine now. I never knew diodes could go weak for a while before failing. It did have a very touchy sync and then, nothing at all. We learn everyday. Thanks for the tip
