Old 10-23-2009, 06:43 AM
roundscreen roundscreen is offline
Originally Posted by DaveWM View Post
checked the vert cent pot, all leads to ground are about 7k which is the same as the B+ load so that looks ok. Thanks for the heads up.
Your welcome, The ctc 16 chassis is a good chassis and will put out a really good picture when you get her working. Here is a picture of my ctc 16 xl.
I really like the cabinet and it has a swivel base. This set had a shorted vert cent pot and it damaged the power supply. I was lucky that it did not take out the power transformer but had to replace all the can caps, B + Diodes, Power switch and the circuit breaker. The person I bought the set from HAD to plug it in and turn it on.
Ed
