Check to see if the width coil was cut out of the circuit earlier as a short cut to increase width. I would avoid shorting the width coil as it will overload the flyback.
I suppose besides L220 being open, or cut out of the circuit as you suggested, L204 could be open between 5-6. John |
The width coil was not taken out of circuit. I temporarily unsoldered one of its leads at the flyback and tested it, as well as the 5-6 connections on the flyback. Neither is open.
I will look at the WW resistors next. Look at how far off-kilter the focus coil has been cranked. Kosher? (If not, why would they give you adjusters with that much leeway?) It looks like none of this stuff, including the CRT, has been touched in ages. Phil
I must be brain dead. They wouldn't design something that can't work would they? If you get bored you might measure the HV at two setting of the width coil. John |
