#36
I took the fine tuning mechanism apart, cleaned and lubed everything. Like on the power tuning, the plastic gear was broken and turned loosely on the shaft. I glued it back together, glue hardening now. The belt is loose, but it will cause the shaft to turn. But I don't know if it will slip when it's all back together and the has added pressure on it of turning those slugs in the tuner. The sams doesn't give a part # for the belt, anyone have that so I can try to order another one?
