Old 12-28-2009, 12:57 AM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
The chrome paint used for plastic models doesn't look too bad.
Then there's this method.
http://www.caswellplating.com/pickak...ticchrome3.htm
John
Old 12-28-2009, 09:10 PM
amptramp's Avatar
amptramp amptramp is offline
VK Member
If I'm not mistaken, chrome plating on plastic usually starts with electroless nickle plating followed by chrome plating. Electroless nickle is a process that does not depend on external electricity and can be used on any surface - you could plate an apple if you wanted to. Then the nickle surface is used as an electrode for electroplating of chromium.
Old 12-28-2009, 10:17 PM
jeyurkon's Avatar
That might be possible. Electroless nickel has improved over the years. Orginally the surface of plastic had to be activated by dipping it in a dilute acidified stannous chloride solution. Then it would be dipped in an electroless copper solution. Once that thin layer formed a thicker bright eletrolytic copper plating was done. Then depending on how bright it was they would either go directly to chrome plating it or polishing the copper first.
John
