According to this ad, it does have a tape deck as original;
http://library.duke.edu/digitalcolle...s.TV0088/pg.1/
“Once you eliminate the impossible...whatever remains, no matter how improbable, must be the truth." Sherlock Holmes. |
"All three sizes, all three speeds." Didn't they have 16/45/33-1/3/78 in '51? Jr_Tech: It does say professional quality tape recorder so you're probably right about the unit. John |
Dave,
Go and get it already. I can store it down in New Hope with my overflow.... Chuck
www.myvintagetv.com Learn from the mistakes of others - You can't live long enough to make them all yourself. |
http://www.imperialclub.com/Repair/A...Way/invent.htm jr |
Wonder what 16 rpm records were available at the time ? jr |
I stand corrected. I knew the technology existed, but I never knew that they included it as a bell or whistle in an early TV. Makes perfect sense that Dumont would be the company to market it. I have always thought that it was sad that this once great company ended up going cheap and junky, then fading completely away. They were once truly the best in the business....... |
I Have one I got back in the early 90's it's a verry high end set it has a decal inside one of the doors that says gurenteed genuine mahogany and that the wood used is from the west indies. It is also verry heavy and solid. I had always wonderd if there were any others left. I get a lot of wow's when people see it since it is such a grand set. If you have room for it get it you won't be disapointed.
Nice set!
Thanks for posting the detailed picture... What I took to be reels on a Magnecord PT-6 recorder appear to be a timer clock and a UHF tuner logo...so where is the tape deck? jr |
It Is in the door on the left side under the record player.
Can you post a picture of the tape unit?
