Old 01-24-2010, 03:25 PM
7"estatdef 7"estatdef is offline
Found the answer to the riddle. Filament winding for the 6W4 was arcing at chaiss under the TV/Phono switch. Will repair by adding a 6v3A transformer. Hope it didn't damage anything else.
Old 01-24-2010, 09:53 PM
ha1156w's Avatar
ha1156w ha1156w is offline
I spy a black beauty capacitor in the bottom left corner next to that transformer. You might consider replacing it while it's up for service.
Old 01-25-2010, 07:09 AM
Oh that's just the one that shocks you when you touch the chaiss and ground.
Terry
Old 01-25-2010, 10:38 AM
marty59's Avatar
marty59 marty59 is offline
Terry
Sure leave a nasty mess behind when they short out and blow!!
Get that thing outta' there!!
Old 02-01-2010, 09:15 PM
Well I disconnected the original filament wiring and hooked up a separate filament transformer for the damper tube. Also replaced the lead on the flyback to the 6BG6 plate cap. Put it all back together and it worker great!!The best picture I've seen on that set. For a hour. Came in here to the computer for a bit and smelled something bad in the other room. I think the replacement transformer didn't have enough insulation and it arced over internally.I could hear it arcing. I not quite sure what happen after that but it toasted the width coil, that's what was stinking up the joint. Lost hv to the crt.
Dug up a transformer with a 3Kv insulation and install that. Replaced the width coil. Wasn't making enough hv and had shrunken picture. Long story short replaced the 6BG6 & 6W4 and it seems to be working great again. I think my wife thinks it's going to set the house on fire!
Terry
ps Anybody got a spare width coil for a RCA KCS-47A?
Old 02-02-2010, 01:19 PM
TV Engineer TV Engineer is offline
This was a common problem with any set that used a 6W4 damper tube. The breakdown voltage from filament to cathode is rather low for a tube subjected to such high pulse voltages.
Replace the 6W4 with a 6AX4, or better yet, a 6AU4. This will prevent this problem from reoccurring.
Old 02-02-2010, 05:51 PM
So is it common to smoke the width coil when the 6W4 goes? Or should I take a look for other problems?
Terry
