Thread Tools | Display Modes |
I watch RTV and the sound is often messed up, is it doing it on all the OTA channels?
I will add that I did swap out the matching transformer, so that's not causing it, unless they both were bad. I doubt it...
Here, Cox Communications muddied the Digital Transition with an all-out advertising campaign for "convert to digital - upgrade your cable service" kinda ads. They were referring to upgrading the QAM boxes to their digital (read:HDTV) service. Half the folks on cable thought the ATSC to NTSC boxes WERE the ones Cox was talking about, and bought them in stores. I got one of my Zeniths for cheap from a lady that experienced that very confusion. The Motorola (Cable) Digital HDTV Boxes are noisy. I get moire/co-channel lines on my RCA roundie (CH3 or 4) unless that sucker is standing on edge (and presumably radiating in the horizontal plane above the set's cabinet). I'm not assailing the OP's intelligence - just wondering what converter he's referring to, given there are "no 'over the air' channels. Cheers,
Also, I see now that I made a mistake in stating that there are no 'over the air' channels. It is STILL 'over the air', what has changed is the TYPE of signal from analog to digital. Sorry for the misinterpretation.
"Face piles of trials with smiles, for it riles them to believe that you perceive the web they weave, and keep on thinking free" |
@Tubejunke
Just a thought, have you tried unplugging the TV and plugging it back in the other way? Perhaps you have a hot-chassis set, a cap has shorted somewhere, and you're putting 120VAC into the tuner when you hook the CECB up to it? Just a thought. Last edited by Robert Grant; 02-24-2010 at 10:10 PM. Reason: fix typo that made me look the a total idiot |
