Old 04-23-2010, 11:46 PM
Tom Albrecht's Avatar
That's probably one of the Philco split chassis sets. I restored one of those a couple of years ago for someone else and had a surprising number of problems with it, although that can happen with any vintage TV.
Best not to power it up too much before replacing the paper capacitors in the horizontal sweep section. Many folks would also advise replacing all the electrolytic capacitors in the power supply as well before powering up (I don't happen to do it that way myself, but it's important to keep in mind that a shorted electrolytic cap can be hard on your power transformer).
You'll also want to figure out quite early in the process whether your picture tube is good. There are a couple of ways to do that: either use a CRT tester (which can often be obtained for very little money), or repair just enough of the TV's circuitry to get the horizontal sweep and high voltage sections working. Then by checking voltages on the CRT cathode and grids, and observing how bright the raster (or horizontal line if the vertical isn't working yet) you can get an idea.
Finding a replacement CRT or having the old one rebuilt takes a bit of time and money if it turns out that yours is bad. Sometimes that means that a particular set is not the best choice for restoration, depending on sentimental value, how much you like the design, etc.
Feel free to ask lots of questions here as you get started.
