Old 05-14-2010, 11:36 AM
rpm1200's Avatar
rpm1200 rpm1200 is offline
Originally Posted by freakaftr8 View Post
I got done with the alignment tonight. This set is fairly easy to converge, believe it or not it has a board with 6 pots dedicated to convergence. It's so engineered (overengineered) that it had an access panel in front of the set just under the controls in the door that you remove 4 screws and there are the RGB drive adjustments. Along with these adjustments are switches to turn on and off each drive to the guns.
I have a Sony rack-mount monitor with the same feature (the pots and cutoff switches are in a little drawer) but it's pretty cool that they put the same feature into a consumer TV. Probably carried over from the CVM-3000...
The 30" CRT in 1981/82 must have been the beginning of the giant CRT's. Did Sony produce the forst CRT to be over 25". I think they were producing 27" CRT's before this 30" weren't they?
I think Sony made 26" color CRTs before anyone else had made a color tube that large, but I think they started doing 27"s later, after the 30". The earliest Sony 27"s I've seen were late 80s, and there are both 26" and 27" Sonys listed in my 1986 J&R Music World catalog. If you count monochrome CRTs, DuMont beat everyone to the punch with their 30"!
