Old 05-21-2010, 12:09 PM
holmesuser01's Avatar
That set probably gets the B+ for the audio section off the flyback. It goes through a small diode, and a 1 ohm resistor used as a fuse. Then, there are some caps for filtering. It's not too bad if you have the schematic to follow.
I used to work on alot of Mitsubs when they were younger. Your set is a pain to move, but I never saw one with a bad kine. Your problem with caps was the typical problem.
Old 05-28-2010, 06:09 PM
Findm-Keepm's Avatar
Followin' the Rules...
Model #? I have a huge database of symptom/cures fo Mitsubishi sets, and may be able to help. Does it have MTS audio? The MTS audio board was famous for problems on these....
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
Old 05-28-2010, 06:31 PM
Cheers,
Brian
