Old 05-26-2010, 12:34 PM
ctc17 ctc17 is offline
FM is transmitted horizontally polarized like TV, so your antenna should be 'flat'. Generally with low power FM stations they use yagis so they can direct the signal exactly where they want it to go.
With am the big stations use 2 or 3 vertical antennas and can direct exactly where they want the main radiated lobe to go by phasing the antennas. Sense it skips all over the place, polarization doesnt matter. The general rule is bigger is better. All the ferrite rod does is makes the coil appear much larger than it really is.
Im not saying that that the front end and IF doesnt affect it, but antenna is the majority.
I have noticed some degradation with KNX, our local CA powerhouse that any radio, even you teeth could pick up at night through CA, NV, AZ on and on. I figured they just cut their power back trying to save money because of the economy.
Old 05-26-2010, 01:23 PM
Many full power FM stations now use circular polarization, in an attempt to provide a better signal to automobile radios and table radios that use "line cord" antennas, so orientation of the line cord or headphone cord in this case, may not be as critical as it once was.
According to the FCC website, KNX still transmits at 50KW.
http://www.fcc.gov/fcc-bin/amq?list=0&facid=9616
Perhaps their ground system has degraded over the years?
Old 05-26-2010, 04:33 PM
Interesting, the antennas for KNX are located in a public park where all the local soccer teams meet. Its says the phase angle is 0 so I wonder if their just broadcasting omni.
Interesting stuff.
Old 05-26-2010, 04:56 PM
I appears that they are only using one tower, so it would be non directional (ND-1 is shown). If you check the "ASRNs within .5 km" list, it appears that there are 2 nearby towers that are owned by CBS, perhaps these were used at one time to provide a different pattern day- to -night.
Update... Scott Fybush to the Rescue....He says that in the late 50s CBS experimented with a directional array...but it did not work out:
http://www.fybush.com/site-020313.html
Last edited by jr_tech; 05-26-2010 at 05:03 PM. Reason: add tower of the week link for LA
