the variable capacitor, but that's no big deal. IF alignment (the slugs in the IF transformers) should not be affected. Rebuilding the coil on its original cardboard core will probably yield better results than trying to fit a 'universal' replacement coil. By the way, the exact number of turns matters more than the length of wire, so try to stay as close to original specs as you can. Also the wire must be enameled (thin coat of varnish rather than bare wire or wire with plastic insulation). This is often sold as 'magnet wire'. Good luck! |
Unfortunately the coil was so chewed up I couldn't reliably count the number of turns.
However, I did piece all the lengths together and I would assume that with the same total length of wire, wound in the same manner (or as close as possible) would result in the same number of turns. I have numerous low voltage transformers that I'm never going to use for anything else- I'd thought to salvage the wire from one of those, provided it's not potted. I also have a huge copper coil (magnet wire) from a TV yoke, but I think that's too thick to use. Fortunately, the secondary coil was untouched, and so I have it for both a reference in wire size and winding pattern. |
