Blast has it, you just have to watch whats going on, and what its not doing. I have one like it and it has a really really good picture on the slow speed. I had the plastic brake arm on the take up reel break off. I got some music wire and melted it into the old brake arm using the tip of the soldering iron. The thin steel wire kept the "spring" in the plastic part and now its been several months and it works well. But switching from play, to FF, or Rew. I have to let all the clicking moving parts stop fully or the unit jams as tape comes off the reel. I have not seen the cause of the new thing as it only happens once in a while. This machine is worth fixing. Use a crappy tape to discover whats going on. And learn how to trick it on with no tape in it so you can see the stuff move that is normally out of view whan the tape is in it. Shake it upside down on a completely clear table just in case some plastic part is broken. The part will fall out than just figure out where its from.
I had a Magnavox VCR like this one in the mid-1990s. It worked quite well the five years or so I had it, but shortly after I moved here in 1999 the heads wore out. The tape drive mechanism was working just fine.
Mag's were made by a number of vendors over the years. At first, mostly Panasonic and a little JVC. Then, sometime in the later 90's by Funai. If memory serves I'm not sure I've ever replaced many Funai heads. Certainly more Panasonics and JVC's.
There was a JVC manufactured machine for Mag in the very early 90's that had a strange head. Every other vendor's head- it never mattered if you turned it back and forth while cleaning it. But, it seems if you turned this JVC backwards (as I later found out) the reverse motion spun a lubricant back out of a spiral groove (per instructions and per my memory) and ruined the head. The 2-head version was the VR9020 and the 4-head the VR9040. This first happened to me in the early/mid '90's while cleaning my friend's 9020. It worked fine before I touched it, I gave it a simple cleaning and BOOM no more video. Gosh, was that head expensive... I think I toasted one more before I figured out what was going on. Fortunately, I didn't see too many of those models... |
I looked at Magnavox's web site yesterday, and found that everything made in the last 10-20 years or so with that name on it is actually made by Funai. In fact, "Magnavox" is now a trademark of Philips Electronics Corporation and is being used under license by Funai.
What a shame to see a once-proud American TV/stereo manufacturer's name on Pacific Rim import electronics that do not last longer than the warranty period, but that's the way of it these days with all of the older brands -- Zenith, Admiral, Emerson, et al., where these brand names are placed on cheaply-made TVs and audio gear without a second thought. I remember the original Magnavox (I have a friend whose parents owned a Magnavox 19" b&w remote TV and a Mag stereo console years ago), and they were excellent sets. The only thing I ever had against Magnavox televisions was that they used PC boards, even in their large, fabulous 3-way entertainment units of the '60s; I have read here that these sets ran extremely hot, which only added to the problem of making the boards extremely brittle, especially around high-power tubes such as the horizontal output. Also, these sets made the electric utility companies rich because of their very high current consumption -- many of them probably drew perhaps 250-300 watts with the stereo on full blast (as was very likely the case in homes with one or more teenagers). If it were possible to operate the TV and the stereo in these consoles simultaneously (I think they were made with a switching arrangement so that such operation would be impossible--you could use either the TV or the stereo, but not both at once), the current draw would increase, of course; I think a console such as this could draw close to 400 watts under these conditions.
Been a while since I overhauled one of those, but the brake problems are usually caused by worn out slider plate (?) that moves the brake arms etc. that is under the cassette loading assy and is operated by a lever you see to the right by the cam gear and mode motor. Was a pretty common problem. Those mechanisms were common in Magnavox TV-VCR combos that would come in under an extended warranty or just out of warranty, people would pay to fix because of the TV. Replace the old white plastic slider plate with a newer tougher gray plastic upgraded part fixes it.
