No, unless the filament winding in the power transformer is overdesigned.
The 80 has a 2-A filament current, while the 5Z3 needs 3-A, so it would most likely overload the transformer. You can grab the 4-pin base from the old 80, add an octal socket with 4 pieces of wire and make an adapter to use a 5Y3GT. I think this is the best possible thing next to an actual 80. Good luck. |
