Hello again,
Well, a spark gap gizmo will indeed produce noise that can be received across the band, but it is a crude instrument at best... I won't start writing an essay about the theory of superheterodyne receivers right away (but I can do it if you tell me it would help). Instead, let's determine if the oscillator is running. When tuned to the bottom of the band (550 kHz or so), the oscillator should be running at 995 kHz, and at the other end of the band (1600 kHz), it should run at 2055 kHz. These figures are just 455 kHz about the desired carrier frequency. If you have two working AM radios in the house, you should be able to do some testing. Just one working radio is actually needed for the test, but two will help demonstrate the procedure. If you set one of the radios at the bottom of the AM band, its LO will run at about 995 kHz as stated above, and if you set the second radio around the latter frequency, you should be able to find a spot where you're just picking up the radiation from the first radio. You have to try it to hear the effect. Now as you increase the tuning of the 'source' radio, you can track its radiation by also increasing the tuning of the 'observing' radio. The trick to check your receiver is to use the same 'observing' radio as above (it will work fine if it is a small portable unit with a speaker), placing it near the oscillator tube (6BE6) in your Fleetwood. You should be able to crudely determine whether the oscillator is running. Let me know what happens next. Good evening. P.S.: the method described, using a small AM radio as a probe, will not work for LO frequencies above the upper limit of the probe (1600 or 1700 kHz), corresponding to carrier frequencies of about 1150 to 1250 kHz. There is no guarantee that an oscillator that works at a lower frequency does not quit at some point in the frequency range. Last edited by electroking; 07-20-2010 at 07:33 PM. Reason: added note |
