Old 07-15-2010, 02:36 PM
W9RAN W9RAN is offline
VK Member
Realizing this is an old thread, I'll just pile on to say that having just gone over a similar Predicta, I found exactly the same modification. The wire to the Vert Lin pot had been cut and an oversized 300 ohm 25 watt sand resistor hacked in it's place. Vertical linearity and height were horrible, but a few minutes with the sub box produced a much improved image with about 900 ohms. I assume this pot is prone to failure, and the 300 ohm value was deemed correct at some point.
Bob
Old 07-30-2010, 06:18 PM
wiseguy wiseguy is offline
Glad i don't have a wife to get mad at me....
I had to try this method of removing rust from a tuner shield from a kenwood kw-1100u amp..interesting as within 3.5 hrs it has dissolved part of the SS spoon off completely..LOL, i find it entertaining.. and interesting..and the rust spots are almost gone..
Old 07-30-2010, 07:55 PM
OP seems to have dropped off the planet.
Old 07-30-2010, 08:15 PM
That's a real nice power supply you've got there!
Maybe he never made it back from Normandy ?
Old 07-31-2010, 07:16 PM
rust removal
The Power supply shot is to Show The voltage and current of the "part" in the bowl was drawing and it's setting..(which was 6 volts).. interesting as soon as you lower the rusty metal part into the salt and water mixture it really draws some power during this process..... this why I am glad I don't have a Wife to get upset at me for using silverware from the kitchen drawer for this ...
Old 08-11-2010, 08:58 PM
hello....
Old 08-14-2010, 04:20 PM
mbates14 mbates14 is offline
hi........
