  #32
Old 08-02-2010, 01:03 PM
Reece's Avatar
Reece Reece is offline
Don't think your xfrmr is at fault if it only gets warm and not hot, doesn't sputter and fry, voltages are normal on secondaries, and voltage from either side of HV to center tap are essentially equal. Look where the wires go into the xfrmr shell: look OK, not frayed?
Might be able to get the switch limbered up if you can get some cleaner in there. If not, might have to replace the volume control/switch. Sometimes they can be carefully taken apart and worked on.
Reece
