Old 08-05-2010, 01:21 PM
It looks something like the foam they sell for putting under camper tops on pickups. Auto parts & hardware stores usually have it. But the brands I've seen are grayish in color, and might not be wide enough.
Old 08-06-2010, 01:26 PM
Ralph S Ralph S is offline
McMaster-Carr has this material as stock item(s)
I've used the following from McMaster-Carr both in my Dumont and RCA sets:
1/4" X 2" X 36" 10A Neoprene rubber #3207K13 $15.22 each
1/8" X 2" X 36" 10A Neoprene rubber #3207K12 $10.16 each
The 10A is the measure of softness and it pretty much matches what you'd expect a manufacturer to use when mounting a CRT.
With the 36" length, you'll probably end up with enough for another set! Good luck.
Old 08-06-2010, 01:46 PM
John Marinello's Avatar
<-- "Byron"
Try your local hardware store, ask for a replacement garage door seal. The one that I bought was "L" shaped (maybe a 1/2" lip), ~2+" wide, ~1/4" thick, ~16 feet long. Decent neoprene rubber that had a smooth finish, cheap. Frickin' lifetime supply...
Old 08-06-2010, 08:16 PM
Some good suggestions, I like the Mc Carr Masters Foam and it sounds right except I need it to be 3" wide (measured it today) I don't see that particular soft foam in that width. I could double up on it since the band is also 3" wide.
I went to Ace Hardware and couldn't find anything that would work, maybe I should try Home Depot or similar.
