Old 08-11-2010, 09:43 PM
miniman82's Avatar
First Light: 1952-2011
Did you get the one I sent you?
Evolution...
Old 08-12-2010, 12:18 AM
I did, thanks. I was able to find a new one after all, so I can return this one to you.
Regards,
Phil
Old 08-12-2010, 03:00 AM
yagosaga's Avatar
yagosaga yagosaga is offline
VK Member
Is there a chance to tune or detune the reactance control until the color bars are in sync?
Old 08-12-2010, 10:54 AM
You can access the top of the reactance transformer, 2T124 in the RCA manual ( http://antiqueradio.org/RCACT-100Tel...Service_Manual ). Is this what you're referring to? That adjuster is named A40 in step 37 of the Sams alignment instructions, http://antiqueradio.org/art/temp/RCA...structions.jpg .
Turning that control while watching the screen, I can change the number of bars but not eliminate them.
I wonder if the frequency is too far off to bring into locking range by that means . . . .
Phil
Old 08-12-2010, 12:23 PM
Originally Posted by Phil Nelson View Post
You can access the top of the reactance transformer, 2T124.... Is this what you're referring to?
Phil, that adjustment should bring the osc. into sync. See if it will lock in solid, or if it still has 'weak' sync. Bill(oc)
Old 08-12-2010, 02:02 PM
I'm not entirely sure what you mean by weak sync, but I can get it to lock on a set of horizontal color bands. They don't roll vertically. Moving that adjuster in one direction makes more bands. Moving it in the other direction makes fewer bands. In between the stable points, the bands roll. Continuing in the fewer-bands direction, the adjuster runs out of travel before you reach the Good Place.
Maybe something fishy upstream . . . ?
Phil
Old 08-12-2010, 03:34 PM
Phil, what does it do with the original crystal in place?
Old 08-12-2010, 07:59 AM
miniman82's Avatar
If I needed it, I wouldn't have sent it to you. Go ahead and keep it.
Evolution...
