Old 08-21-2010, 06:56 AM
JB5pro JB5pro is offline
I think it is an incedible and beautiful thing that all of you great men are doing to restore these 15G's. I just had to write that.
It will be amazing to me to someday see a picture on one in person.
Old 09-22-2010, 07:41 AM
jhalphen's Avatar
jhalphen jhalphen is offline
Good day Gentlemen,
I have been procrastinating over the summer (RACS closed) to decide weither to send my working 15GP22 for rebuild straight away, or attempt a last resort test to revive the nearly dead Red gun.
I have also received 2 sturdy CRT boxes to ship the 15Gs.
As of now, Blue & Green guns are A-OK, the Red gun needs a "preheat" for 30-40min at 7V to display red. If the set rests for a week, the process must be done again.
RACS suggested i do the following test to decide if the Red gun is revivable before deciding to ship it to them:
TV off, socket removed, power to filament only:
- 7Volts, 1min
- 9V, 1 min
- 10V, 1 min
- 12V, 2min
Reduce to 9V, "cook" for 45min.
Then, Connect K(Red) to G1(Red)
- Connect a 40W/220VAC light bulb between K+G1(Red) and G2 (Red)
- Apply a 300VDC source between K+G1(Red) and G2 (Red)
- Duration 30 to 45 min.
Question 1: i have a solid-state DC/DC converter, 9V to 300V, 30mA, do you think this intensity is enough?
Option 2: Eckhard is kindly offering help under the form of a Müter BMR90 or Müter BMR 107 CRT rejuvenator.
Quote from Eckhard:
"I have brought an absolutely weak red gun (zero beam current) back to life with 0.9 mA after rejuvenating and with a lifetime guarantee of 2,000 hours (according to the manual). The rejuvenator has a computer-function which measured the actual emission of the gun and computes the exact rejuvenating power for the best results". - sounds encouraging!
If i go for this option, i will need to build a socket adapter for the 15G. From the GE pdf on the 15G it uses a JETEC-20A type base (see refresher data below).
Would somebody have a NOS, second hand, retrievable connector from a dead PMT tube or a source that still sells these? i looked at Digikey's bewildering choice of connectors, got lost & found nothing. If you have something, please PM me with price + Airmail to France.
Hammamatsu Photonics sells new ones for use with nuclear research PMTs. Before contacting them ( high $ price and probably won't sell alone without a PMT tube order) i am trying my luck here with the ressourceful VK gang.
Once this is sorted out, 1 or 2 of my 15Gs will be sent to RACS for rebuild.
Thanks! for reading this long message,
Best Regards
jhalphen
Paris/France
