What chassis does it have? I just learned that the CTC 15s, 16s and their clones had a lot of intermittent connections on the chroma board. I have a set with the red doing what yours is doing and mine's a 15 clone.
You could also hook up a CRT tester and leave it on red for a while, gently tapping the neck to see if there are any fluctuations in the emission or if the filament flickers.
crt red gun
its a ctc16, when i tap on the neck it flickers, im going to see if the connections are good in the socket, i already sprayed some cleaner in but ill give it another try. im hoping the tube is good, i can do a cataract repair and it should be up and running.
crt red gun
by the way, all the guns are lit in the neck
