Old 10-27-2010, 06:40 AM
Originally Posted by Findm-Keepm View Post
Dave,
What is the "power factor" you refer to - and how do you test it?
I've heard of value, ESR, leakage, and dielectric absorption tests for e caps, but this is the first I've heard of power factor.
Cheers,
I use an old heatkit condenser check (uses an eye tube, and a balanced bridge cirsuit for check caps) good of vintage gear esp leakage test at rated voltage, but can not check caps in circuit. there is a "power factor" adjustment, you turn to null the eye tube, which I think is about the same as ESR.
Old 10-27-2010, 11:27 PM
Findm-Keepm's Avatar
Followin' the Rules...
Aw geez, now I gotta buy anudder piece of equipment. Jes' when you think you have everything.....
Thanks! I've got some old Heath stuff - I'll have to see what I've got stashed away. I may have one of them varmits. Probably similar to my Sprague tester's eye tube checks - some kind of reactance vs value check.
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
Old 10-28-2010, 07:41 AM
I think I may have found the vert prob, after going thru every cap (all good) I finally did a swap on one of the vert out transistors, but now the stupid converter box is on the fritiz so I cant get a signal to check it out on. I cant believe what pure junk these DTV boxes are, this is the second one that went out, less than a year old. I have other video RF sources, but it will have to wait for a bit.
I did a quick check last nite and it looked fixed, so I was going to check again this am.
Old 10-28-2010, 07:45 AM
sampson159's Avatar
sampson159
good job.those vertical transistors can have dirty socket issues.had more than a few.post more pics.the crt looks sharp and bright.
Old 10-28-2010, 08:39 AM
Zenith26kc20's Avatar
Watch out for the vertical controls. I have replaced many of them for the problems you describe.
Old 10-28-2010, 08:56 AM
the little pots on the back of the pcb? should I try an test them in circuit?
I have cleaned the transistor sockets, and the serv switch.
Old 10-28-2010, 08:58 AM
I guess the smart thing to do would be to touch those pots when it acts up...
