Old 10-29-2010, 01:24 AM
Ex-Philco
Decent set. I always thought they were "cute" because they are a shrunk version of a 21 inch TV that looks identical.
It is an entry level TV for '56. Could use a yoke cover if you can find one. Finding a high voltage cage top will be more difficult, but it will work OK without it. The horizontal hold control is the oscillator stabilizer so it can get way off frequency if it is out of adjustment. It has no stop like a control pot.
Has a good, stable picture when working. Make sure the solder board ground connections are solid. Heat the chassis lug to fix them. Avoid too much heat on the board.
